Date/Time: Wed, 22 May 2024 01:18:12 +0000
switch off - AutoSnap Sensivity
View Count: 966
[2017-02-03 03:57:51] |
nicktrader - Posts: 665 |
I use the retracement tool as a rectangle tool because of the level setting. Is it possible to switch off complety the "AutoSnap Sensivity" function. If I want draw a "simple" rectangle with the retracement toll inside of a chart with bars on a specific price line the tool is "jumping" from a low/ high of a bar to the next. Thanks |
[2017-02-03 04:14:01] |
Yes of course. Disable auto snapping through Tools >> Auto Snap on Creation/Adjust.
