Date/Time: Sun, 05 May 2024 09:11:56 +0000
How to use CPP fil?
View Count: 1306
[2013-08-10 15:34:52] |
User25261 - Posts: 24 |
HI, I got an indicator on CPP fils and i don't know ho to use it with SC? Can you please give some help here:)? Thanks |
[2013-08-10 18:26:22] |
ganz - Posts: 1048 |
User25261 hi http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html#stepbystep gd lck |
[2013-08-10 19:34:24] |
THnaks:)
[2013-08-10 23:09:21] |
There are better instructions for this particular case and they are here: https://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
