Date/Time: Tue, 21 May 2024 09:57:12 +0000
hollow bars amd fill in
View Count: 728
[2017-02-02 11:15:23] |
User713850 - Posts: 33 |
Hello, I would like to know how to "paint" existing hollow white bars red/green if the avg of the last two bars cum delta tick and cum delta volume are running in the same direction? I assume this would require me to set an alert condition by writing a forumal in the alert condition box? If so, are there any good example formulas for writing this type of alert condition? Thanks Date Time Of Last Edit: 2017-02-02 12:02:39
[2017-02-02 18:08:18] |
This can be done with the Color Bar Based on Alert Condition study: http://www.sierrachart.com/index.php?page=doc/ColorBarBasedOnAlertCondition.php You will have to work out the specific formula yourself. There are many examples here: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#FormulaExamples Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
