Date/Time: Fri, 03 May 2024 18:42:50 +0000
500 tick chart
View Count: 3701
[2013-08-10 14:05:22] |
garygoglia - Posts: 17 |
Hello, I am new to Sierra and trying to figure out if I want to switch from NinjaTrader which I have been using for 2 years... I am trying to load a simple 500 tick chart same as it would be on Ninja and it doesn't look anything like it and I'm not sure what I would choose from the options... I have intraday chart, range per bar-standard (in ticks) 500... and it is only showing me 1 bar all day... Please help... I know all tick charts will display candles different due to data feed but I am not able to get the same chart that I am currently trading... Thanks Gary |
[2013-08-10 21:41:22] |
Sawtooth - Posts: 3992 |
Choose 'Number of Trades Per Bar'. The term 'tick' more accurately refers to the smallest increment of price movement. |
[2013-08-11 17:25:45] |
Tom... Thanks for the response. I did what you said with the 500 trades per bar and it is still way off from what I am trying to get... There are 27 total bars for the day on friday for Sierra and my ninjatrader set to a 500 tick chart had 27 bars by 9:25am EST... Not sure what to do. Thanks Gary |
[2013-08-11 19:09:21] |
Is the 'Intraday Data Storage Time Unit' set to 1 Tick? To access the setting, go to Global Settings >> Data/Trade Service Settings. If it wasn't set to 1 tick, you'll need to re-download the data: Edit >>Delete All Data And Download. |
[2013-08-11 19:10:59] |
Yes it is set to 1 tick... Thanks Gary |
[2013-08-11 21:42:38] |
M5amhan - Posts: 468 |
try posting the chart and posting your Chart Settings > Main Settings |
[2013-08-11 22:13:08] |
You need to use the Number of Trades Per Bar Bar Period Type. This is fully documented here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Also follow the tick by tick data configuration instructions: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Most likely the reason for the difference is because you are comparing a cash market to a futures market. We see you are using the Sierra Chart Real-Time and Historical Forex and CFD Data Service. This does not provide futures data. Only cash/spot market data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-11 22:24:36] |
Can you please tell me how to get on the futures market... I am on a free trial and I thought that was my only option. Thanks Gary. |
[2013-08-11 23:30:56] |
Please refer to the section here about futures data: https://www.sierrachart.com/index.php?l=doc/data.php#FuturesData If you have a futures trading account, you just need to set Sierra Chart to work with it assuming it is with a supported trading service. Which is most likely. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-11 23:31:28
