Date/Time: Fri, 03 May 2024 01:16:42 +0000
View Count: 1385
[2013-08-10 08:20:12] |
User90848 - Posts: 57 |
Date Time Of Last Edit: 2015-04-29 14:01:00
[2013-08-10 23:22:10] |
M5amhan - Posts: 468 |
the historical bar is correct (RJ#), you are using intraday data for plotting a daily chart in the picture you named "intraday chart" typically the best use for RJ# symbol is for monthly/weekly charts or just long term data try going to Chart Settings and changing "Intraday Chart" to "Historical Chart" in the drop down menu at the top, this will give you a more accurate daily chart and will use settlement closes as well rather than midnight closes as you are doing now either way though, RJ# bar is correct Date Time Of Last Edit: 2013-08-10 23:22:48
