Date/Time: Tue, 21 May 2024 17:44:49 +0000
How to setup 2 OCO orders for one Transaction
View Count: 760
[2017-02-01 13:39:16] |
User33743 - Posts: 83 |
Hi, I uploaded File with description. I'd like to have 2 OCO ORDER (TP,SL), but seems that it doesn't work like i thought, so would you like to tell me, what Type of order should be used as type for SL 1 SL2 AND TP1,TP2? 2. Would be SL 1, SL2 treated on chart as two Different Line so i could managed tham separately? Best Regards |
MARKET.jpg / V - Attached On 2017-02-01 13:33:30 UTC - Size: 51.63 KB - 251 views market2.jpg / V - Attached On 2017-02-01 13:35:06 UTC - Size: 34.69 KB - 245 views |
[2017-02-01 13:54:09] |
Adding description. It should be - When Price hit TP1, SL1 is also removed but stil there is a position with 1 contract SL 5tick, TP- 50Tick. When it hits SL1, TP1 is also removed. |
[2017-02-03 06:32:30] |
You just need to add another Target Attached Order and it will be of a Limit order type. This is all. It will be listed as Target 2. Here is the documentation: Attached Orders: Step-By-Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-03 06:35:38
