Date/Time: Sun, 05 May 2024 08:18:54 +0000
crude oil
View Count: 1255
[2013-08-08 22:37:56] |
M5amhan - Posts: 468 |
today's settlement is incorrect for crude oil, will you please look into this thank you |
[2013-08-09 17:59:41] |
Do you still notice a problem with this after re-downloading the data?
[2013-08-09 20:12:52] |
no it was fixed, thanks
