Date/Time: Sat, 04 May 2024 02:57:24 +0000
Can I display the Forex Chart on per pip increment?
View Count: 2971
[2017-01-25 06:20:05] |
User879200 - Posts: 1 |
Can I display the candlestick price have a price scale in increment of 1 full pip? Kind of like the attached file. I have tried some way, and already set the tick size to o.ooo1, but still didn't seem to work.. |
螢幕快照 2017-01-25 14.17.21.png / V - Attached On 2017-01-25 06:17:54 UTC - Size: 224.5 KB - 568 views |
[2017-01-25 06:52:50] |
Yes you can by using this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s308 (Round Price Bars to Tick Size) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-05 13:53:52] |
Giorrgi - Posts: 3 |
Hello, I've used the Round Price bars to tick size study and my candles now move on 0.5 tick increments instead of 1 full pip (EUR/USD), for example 1.05355 instead of 1.0536. Is it possible to round to 1 full pip? Thanks. |
[2017-03-05 20:10:50] |
Yes by adjusting the chart Tick Size setting: Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-05 20:11:34
[2017-10-29 23:13:11] |
User788855 - Posts: 8 |
Hi, When I go to this link: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s308 It shows this study has no inputs.What to do? |
[2017-10-30 02:20:55] |
So what you need to do is add this study to the chart: Round Price Bars to Tick Size And adjust the Tick Size in Chart >> Chart Settings to what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-30 03:20:43] |
Ok,I figured it out. Many thanks :) |
