Date/Time: Sun, 19 May 2024 08:29:07 +0000
Problems with 2 monitors
View Count: 681
[2017-01-23 17:29:57] |
ivan100 - Posts: 2 |
Hallo!I have problem.I have data from sierra chart and when I added second monitor,because I need too use 2 monitors for trading on second monitor, data from sierra dosnt work.Before I had to install second program from sierra chart,on same computer and I think maybe something there is any problem,but I dont know where.Can you help me?
[2017-01-23 17:39:43] |
If you need to run 2 separate copies of Sierra Chart, and you want to receive the Sierra Chart Exchange Data Feed into both, then you need to use the New Instance feature which is documented here: http://www.sierrachart.com/index.php?page=doc/DTCServer.php#UsingDTCServerForDataAndTradingInAnotherSCInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
