Date/Time: Sun, 19 May 2024 07:45:08 +0000
Log error
View Count: 589
[2017-01-23 15:34:06] |
User11010 - Posts: 7 |
Reading Internal Order ID file. | 2017-01-23 14:47:36 Reading Trade Orders file. | 2017-01-23 14:47:36 Reading Trade Positions file. | 2017-01-23 14:47:36 Software version: 1507 | 2017-01-23 14:47:36 Uses New Spreadsheets | 2017-01-23 14:47:36 Usage end date: 2017-03-29 | 2017-01-23 14:47:36 Enabled for: Advanced Features. | 2017-01-23 14:47:36 Enabled for: Advanced Features 2. | 2017-01-23 14:47:36 Enabled for: Sierra Chart Historical Data Service. | 2017-01-23 14:47:36 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-01-23 14:47:36 Current selected Data/Trading service: IQFeed | 2017-01-23 14:47:36 Chart Update Interval: 500 | 2017-01-23 14:47:36 Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2017-01-23 14:47:36 2017-01-23 14:47:50 Local computer time | 2017-01-23 14:47:36 2017-01-23 14:47:50 Local computer time in UTC | 2017-01-23 14:47:36 2017-01-23 14:47:50 Local computer time in SC Time Zone | 2017-01-23 14:47:36 2017-01-23 14:47:37 Server time in UTC | 2017-01-23 14:47:36 Local computer UTC time and Server UTC time difference: 5 seconds. | 2017-01-23 14:47:36 Program path: C:\SierraChart\ | 2017-01-23 14:47:36 Data Files path: C:\SierraChart\Data\ | 2017-01-23 14:47:36 OS Version Number: 6.2 | 2017-01-23 14:47:36 Locale Setting: C | 2017-01-23 14:47:36 IQFeed | Connecting. | 2017-01-23 15:24:23 IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-01-23 15:24:23 * IQFeed | Connecting to Admin port 9300 | 2017-01-23 15:24:23 Socket (87) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-23 15:24:24 Socket (87) | Shutdown and closed. | 2017-01-23 15:24:24 IQFeed | Disconnected from Admin port. | 2017-01-23 15:24:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-23 15:24:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-23 15:24:24 Starting DTN IQ Feed interface software. | 2017-01-23 15:24:24 Error starting IQ Feed interface software. Error code: 2 | 2017-01-23 15:24:24 * IQFeed | Disconnected. | 2017-01-23 15:24:24 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-23 15:24:24 IQFeed | Connecting. | 2017-01-23 15:26:24 IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-01-23 15:26:24 * IQFeed | Connecting to Admin port 9300 | 2017-01-23 15:26:24 Socket (89) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-23 15:26:25 Socket (89) | Shutdown and closed. | 2017-01-23 15:26:25 IQFeed | Disconnected from Admin port. | 2017-01-23 15:26:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-23 15:26:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-23 15:26:25 Starting DTN IQ Feed interface software. | 2017-01-23 15:26:25 Error starting IQ Feed interface software. Error code: 2 | 2017-01-23 15:26:25 * IQFeed | Disconnected. | 2017-01-23 15:26:25 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-23 15:26:25 IQFeed | Connecting. | 2017-01-23 15:28:25 IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-01-23 15:28:25 * IQFeed | Connecting to Admin port 9300 | 2017-01-23 15:28:25 Socket (91) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-23 15:28:26 Socket (91) | Shutdown and closed. | 2017-01-23 15:28:26 IQFeed | Disconnected from Admin port. | 2017-01-23 15:28:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-23 15:28:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-23 15:28:26 Starting DTN IQ Feed interface software. | 2017-01-23 15:28:26 Error starting IQ Feed interface software. Error code: 2 | 2017-01-23 15:28:26 * IQFeed | Disconnected. | 2017-01-23 15:28:26 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-23 15:28:26 IQFeed | Connecting. | 2017-01-23 15:30:26 IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-01-23 15:30:26 * IQFeed | Connecting to Admin port 9300 | 2017-01-23 15:30:26 Socket (93) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-01-23 15:30:27 Socket (93) | Shutdown and closed. | 2017-01-23 15:30:27 IQFeed | Disconnected from Admin port. | 2017-01-23 15:30:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-01-23 15:30:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-01-23 15:30:27 Starting DTN IQ Feed interface software. | 2017-01-23 15:30:27 Error starting IQ Feed interface software. Error code: 2 | 2017-01-23 15:30:27 * IQFeed | Disconnected. | 2017-01-23 15:30:27 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-01-23 15:30:27 Date Time Of Last Edit: 2017-01-23 17:59:03
[2017-01-23 18:12:00] |
To use IQ Feed, follow through the setup instructions here: http://www.sierrachart.com/index.php?page=doc/DTNIQFeed.html#Setup You need to follow step 2 and install the IQ Feed client software. There is also the Sierra Chart Exchange Data Feed that you might want to use instead: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
