Date/Time: Sun, 19 May 2024 11:19:27 +0000
not a valid building Renko graph in realtime
View Count: 692
[2017-01-23 10:14:09] |
User150435 - Posts: 17 |
Hello. The problem is this: not a valid building Renko graph in realtime. The bottom line: if you include Renko chart at the moment it displays the correct story but if you do nothing with the schedule nachinaetsya not displayed correctly. There is a real map and historical. How to do so would in the real construction of the Renko chart Screenshots will be in session. At the moment, you can see historical quotes unchanged |
Буфер обмена-1.jpg / V - Attached On 2017-01-23 10:12:42 UTC - Size: 146.13 KB - 229 views |
[2017-01-23 12:15:54] |
Here is an example: in the screenshot 1, we see realtime quotes Renko at the moment. I did not add anything not clean up the schedule so hanging over hours. But as soon as I start to make some kind of action to the schedule (cashing F5 to refresh generally do something) Renko schedule changes. I do not understand why, and why it depends. Maybe you can help me |
Буфер обмена-1.jpg / V - Attached On 2017-01-23 12:12:55 UTC - Size: 160.94 KB - 217 views Буфер обмена-2.jpg / V - Attached On 2017-01-23 12:13:31 UTC - Size: 211.55 KB - 224 views Буфер обмена-3.jpg / V - Attached On 2017-01-23 12:15:42 UTC - Size: 159.45 KB - 224 views |
[2017-01-23 18:18:29] |
Do not use any of the Renko studies. Remove all of those from the chart. Only use the Renko Bar setting in Chart Settings. Here are instructions: http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
