Date/Time: Sun, 19 May 2024 10:07:09 +0000
Chart Drawing Data Export
View Count: 1282
[2017-01-23 08:57:12] |
User34124 - Posts: 271 |
How can User-Draw Chart Drawings be exported to a Data CSV file, similar to how Bar Data is extracted? If a script needs to be programmed, which function would I need to use? For example, if I have 50 rectangles drawn on a chart, and I execute script, then all of the anchor points of each rectangle get pasted to a script. This is what I am trying to achieve and I can only find information on the code itself drawing onto the chart, not vice versa. Chart Drawings obviously get stored when a Chartbook is saved, so that is a point to consider maybe. How is the data saved and where? Excuse my inexperience on this. Many thanks. |
[2017-01-23 09:33:29] |
You will need to use ACSIL and use this particular function to access the Chart Drawing data: Using Drawing Tools From an Advanced Custom Study: sc.GetUserDrawnChartDrawing() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-23 09:33:52
