Date/Time: Sun, 19 May 2024 09:16:26 +0000
User defined studies added to new Instance
View Count: 745
[2017-01-22 10:11:47] |
User513952 - Posts: 84 |
How can I add two new studies (INST and KDJ in main account) into the new Instances?
[2017-01-22 20:40:50] |
How are these studies created specifically? In general, you will want to take the files associated with them from the Sierra Chart Data folder from the instance they are currently in and copy them to the Data folder of the other instance of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
