Date/Time: Sun, 19 May 2024 04:37:19 +0000
How to show price on right side of chart?
View Count: 935
[2017-01-22 07:25:14] |
User701247 - Posts: 117 |
Please see attacted image, I would like to know on How to show price on right side of chart. Does anyone have any suggestions? Thanks in advance for any suggestion. |
Price2.png / V - Attached On 2017-01-22 07:24:05 UTC - Size: 19.5 KB - 232 views |
[2017-01-22 09:09:26] |
http://www.sierrachart.com/index.php?page=doc/helpdetails9.html
[2017-01-22 09:14:56] |
Also, if we get further questions like this from you, we are not going to be responding. Our patience has run out with these kinds of questions. You are creating your own problem. The solution should be very obvious to you. And we are very suspicious at this time, that you are intentionally asking us questions you know the answer to, in order to be an abuse to us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-22 11:31:58] |
I am a newbie on Sierra Chart and get a lot to learn. Thank you very much for helping me and I am grateful for your help. Thanks you very much for your suggestions |
