Date/Time: Sun, 19 May 2024 12:15:10 +0000
How to programatically access Numbers bars
View Count: 619
[2017-01-22 07:20:55] |
AcquaLife - Posts: 33 |
Hello, I have numbers bar on my chart, but i am confused on what function i would use to access it in my study. Basically, I want to be able to programatically store the point of control number that is in the in the numbers bars study. Thanks |
[2017-01-22 09:08:19] |
Refer to: ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars You will have to calculate the point of control yourself though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
