Date/Time: Sun, 19 May 2024 06:24:30 +0000
Close for Point and figure
View Count: 676
[2017-01-21 20:42:49] |
User15414 - Posts: 20 |
Could you please include close of bar for calculating point and figure. It changes the look drastically to nice and clean patterns.Using high low only creates blobs of unclear movement. I don't know why but close data is so much better. The renko chart has an option to use close data why not Point and Figure?
[2017-01-21 21:07:14] |
You need to use the Point and Figure Chart study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s140 There is specifically an Input which supports using the closing prices of the chart bars only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-21 21:10:00
[2017-01-21 21:12:34] |
Actually we now see what the problem is. You are running an older version of Sierra Chart and most likely that version does not have that Input. You need to update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-22 01:46:47] |
Awesome! Thanks
