Date/Time: Sun, 19 May 2024 06:24:11 +0000
ACS - sc.ArraySize
View Count: 641
[2017-01-21 18:07:36] |
jizzary - Posts: 177 |
documentation error "sc.ArraySize applies to the sc.BaseDateTimeIn[], sc.BaseDataIn[][], and sc.Subgraph[][] arrays." what is - sc.BaseDataIn[][] should be - sc.BaseData[][] ... right ??? |
[2017-01-21 19:48:44] |
No, you are not right. This is also documented: sc.BaseDataIn[][] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-21 23:01:11] |
correct. documented. but not mentioned ar all at Working with ACSIL Arrays and Understanding Looping so i wonder whether exists ? whether imprecise documentation ? or just for backward compatibility ? are they exactly the same ? why maintain both of them ? is using sc.BaseData[][] preferred over sc.BaseDataIn[][] (due to long term support consideration) ?? |
[2017-01-22 07:29:22] |
They are both documented here: ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][] are they exactly the same ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
