Date/Time: Sun, 19 May 2024 12:15:31 +0000
[User Discussion] - ACS - SCFloatArray - wrong definition
View Count: 1763
[2017-01-21 13:25:06] |
jizzary - Posts: 177 |
(URL:Working with ACSIL Arrays and Understanding Looping: Array Types) SCFloatArray : This is an array of 4 byte float variables. This is the type of array used with the sc.BaseData[] and sc.Subgraph[].Data arrays. This type of array is a reference to an array which is internally allocated and maintained within Sierra Chart. It does not contain a copy of the data. Only a reference to the data. The contents of this type of array can be modified by the study function. pls refer the bold text (i made it bold) it contradicts the previous line and it looks like a mistake as SCFloatArrayRef is defined to be "This type is a reference to a SCFloatArray array" either i failed to understand, or yout definition is wrong pls explain or fix the definition |
[2017-01-22 09:13:23] |
This is not within the scope of our support to explain this. If you do not understand the definitions, it is not actually relevant. And if you want to complain further, go ahead but we are not going to respond. You are only unnecessarily taking our time and taking away development time for the benefit of our users. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-22 09:37:43
