Date/Time: Sun, 19 May 2024 08:47:31 +0000
Every High Plot Indicator
View Count: 677
[2017-01-20 19:13:20] |
markuz - Posts: 90 |
I'm trying to replicate an indicator which plots the highest point in a developing chart and then tracks that point forward until a new high is made. This wasn't possible using the highest high / lowest low. I have attached a picture of the indicator i'm trying to replicate. It is the Top Green dashed bar. You can see it plots the highest point then continues at that point until a new high is reached. Any advice would be appreciated. |
High_Plot.png / V - Attached On 2017-01-20 19:13:04 UTC - Size: 516.62 KB - 233 views Attachment Deleted. |
[2017-01-20 21:47:50] |
Yes you can do this with the Daily OHLC study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s137 Specifically refer to this section: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#DailyOHLC_DisplayingTheHighAndLowLinesIncrementallyForDay You can hide any Subgraphs you do not want to display. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-20 21:48:37
