Date/Time: Sat, 04 May 2024 06:23:14 +0000
lack of data on 5 minute chart
View Count: 634
[2017-01-20 01:13:54] |
User509625 - Posts: 1 |
Hello i am currently using a 5 minute chart with session time 9:30 to 16:00 which should be a total of 78 bars however I am only receiving 64 total and was wondering what I am doing wrong? See screenshot for reference.
Sierra Charts only showing 64 bars instead of 78.jpg / V - Attached On 2017-01-20 01:11:21 UTC - Size: 241.12 KB - 229 views |
[2017-01-20 03:09:28] |
If there is actually missing data, then follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#RetryDownloadDataInChart If there is still missing data, then use the Chart Values tool: http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValues Go through each chart bar and see which ones are missing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
