Date/Time: Sun, 05 May 2024 14:45:11 +0000
[User Discussion] - odd bar duration on the last bar of the day using the numbers bars calculated values study
View Count: 1551
[2013-08-07 14:32:48] |
trademechanics - Posts: 29 |
Can you reproduce this odd bar duration on the last bar of the day. This is ES symbol, with a bar period of 8 Range Per Bar - True(in ticks), with a start time of 8:30 and end time of 15:14:59 using Chicago time. |
foot_duration.png / V - Attached On 2013-08-07 14:32:38 UTC - Size: 75.98 KB - 545 views |
[2013-08-08 05:50:35] |
This is how it is and it is not something we have time for or willing to spend time on.
