Date/Time: Thu, 02 May 2024 13:31:23 +0000
Graphic Settings - Global
View Count: 1185
[2017-01-19 23:57:00] |
User488039 - Posts: 114 |
Please disregard the previous question below. I see you're picking up the color for Depth Percentage from "Trade Dom Value Text". I have the Dom customized color wise (see attached), and I was hoping to set the Depth Percentage to white, but I can see now it doesn't have a separate color setting. Is there a study where I can set how many Market Depth Levels, and then the display the Percentage of Buys/Sells on the chart? Please see attached. Thanks I want to change the color of the following settings, but I can't seem to find them. What's strange is the Trade Dom Ask & Bid Depth Quantities are set to White, but the Depth Totals and Depth Percentages are Black. Please tell me what they are called. Display DOM Depth Totals Display DOM Depth Percentages Column Background Color for... Combined Bid/Ask Market Depth Pulling/Stacking Date Time Of Last Edit: 2017-01-20 07:17:42
Captured Image_25.png / V - Attached On 2017-01-20 07:15:49 UTC - Size: 9.95 KB - 238 views Captured Image_24.png / V - Attached On 2017-01-20 07:16:00 UTC - Size: 53.75 KB - 252 views |
[2017-01-20 10:03:40] |
These are controlled by the Chart Text color. Refer to: Global Trade Settings Windows: Display DOM Depth Totals (Global Settings >> Chart DOM Settings >> Other>> Other Settings) There is no background color for this: Column Background Color for... Combined Bid/Ask Market Depth Pulling/Stacking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-20 17:57:33] |
Hi, When adjusting graphics on the Dom under Chart/Graphic Settings, there is no Chart Text setting. There is a Trade Dom Value Text that controls the center price color. I'm trying to make the Depth Totals and Depth Percentage the same color as the depth level color (white), rather than black like the Value Color. Thanks Date Time Of Last Edit: 2017-01-20 18:02:23
[2017-01-20 18:24:43] |
Yes in the case of the Trade DOM, it is the Trade DOM Last Price/Quantity Text color setting. I'm trying to make the Depth Totals and Depth Percentage the same color as the depth level color (white), rather than black like the Value Color. This is not supported.
