Date/Time: Mon, 06 May 2024 20:22:01 +0000
Historical forex daily data missing for 18/1
View Count: 681
[2017-01-19 19:56:31] |
phaedonk - Posts: 350 |
EURAUD, AUDUSD, USDCAD, could be others. Re-downloading does not fix it.
[2017-01-19 21:34:33] |
Are those the exact symbols of the chart? Or are you using symbols like ^EURUSD?
[2017-01-19 22:25:45] |
Yes, ^EURUSD. It is fixed now, probably a glitch on the fxcm server? |
[2017-01-19 23:30:44] |
No, that data comes from Barchart and they were notified and it is now fixed.
