Date/Time: Fri, 03 May 2024 11:44:02 +0000
Release change
View Count: 680
[2017-01-19 16:37:31] |
ktfroy - Posts: 85 |
In reference to release #1504, "When hiding/unhiding a study through the Analysis menu or directly from the chart, the studies are no longer fully recalculated." What impact will this have on a study that is hidden but used in another study calculation? |
[2017-01-19 16:52:50] |
User460064 - Posts: 12 |
Maybe it should be a decision of the user. It could be another tick box option of each study.
Date Time Of Last Edit: 2017-01-19 16:53:41
[2017-01-19 17:53:51] |
Both of you have a misunderstanding about this. There is zero impact for the user. Only a performance improvement. The studies are still calculated even when hidden. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
