Date/Time: Sat, 27 Apr 2024 14:31:31 +0000
Control bar command
View Count: 863
[2017-01-19 16:19:48] |
ktfroy - Posts: 85 |
Is there a BE command available for the control bar? and what of the possibility of BE +/- X ?
[2017-01-19 18:04:17] |
No. But there are keyboard shortcuts available: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#KeyboardShortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-20 13:28:53] |
I will keep an eye out for it - I was grateful to see the Chartbook buttons being enabled after being told not possible.
1-20-2017 8-19-37 AM.bmp - Attached On 2017-01-20 13:26:38 UTC - Size: 70.24 KB - 282 views |
