Date/Time: Sun, 05 May 2024 07:08:05 +0000
Customize TradeDOM Columns background
View Count: 740
[2017-01-19 09:54:10] |
User252419 - Posts: 235 |
Is it possible to see the background representation of size like I have in the Bid Size/Buy Column in the following columns? -Recent Bid/Ask Volume -Current Traded Total Volume Thank you Date Time Of Last Edit: 2017-01-19 09:54:25
size background.PNG / V - Attached On 2017-01-19 09:54:22 UTC - Size: 20.68 KB - 198 views |
[2017-01-19 18:29:39] |
No.
