Date/Time: Sat, 18 May 2024 23:41:42 +0000
Spreadsheet Global Graphic Settings
View Count: 587
[2017-01-18 08:04:30] |
User787778 - Posts: 139 |
Will you please add a setting for: Default Custom Background Setting
[2017-01-18 18:03:10] |
There is already a default background color. It is in Global Settings >> Graphics Settings: Spreadsheet Default Background Color. We really do not know what you are asking for, but it is very unlikely we would add anything new unless there is some serious limitation which currently exists. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-18 18:03:23
[2017-01-18 19:03:03] |
It would be helpful, if, when one selects: Spreadsheet Cell Properties Background Color Custom the previous selected color or a default color would be retained rather than the selection revert to white each time. Thanks |
