Date/Time: Sat, 18 May 2024 20:37:20 +0000
your chart is still wrong .please see the red circle .it is easy to find ,I have surrouded
View Count: 662
[2017-01-18 05:29:17] |
User166767 - Posts: 32 |
your chart is still wrong,when the data is connected ,I have surrounded by the red circle.please check.
QQ截图20170117232555.png / V - Attached On 2017-01-18 05:29:08 UTC - Size: 62.64 KB - 203 views |
[2017-01-18 06:52:07] |
There is not historical data being maintained for the symbol (M6A) and that could potentially be the reason for the problem and in any case, it certainly would be an issue with missing data. Historical data is now being maintained for the symbol. Go to that chart and select Edit >>Delete All Data and Download. There is now going to be historical data and the chart bars will be correct. Tell us what other symbols you are trading so we can make sure historical data is being maintained. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-18 07:02:47] |
now It is right ,what is the reason ,the chart is wrong,can you tell me ,donot let the question produce again.
QQ截图20170118010049.png / V - Attached On 2017-01-18 07:02:40 UTC - Size: 32.5 KB - 181 views |
[2017-01-18 07:05:21] |
We gave the reason for the problem in post #2 above.
[2017-01-18 07:08:16] |
thank you ! I have no question.
