Date/Time: Sat, 04 May 2024 20:27:39 +0000
color bug
View Count: 1349
[2013-08-07 11:57:45] |
tubular2000 - Posts: 17 |
i have the following color problem: i have set the connecting line to use two colors depending on trade result. but every time i run a backtest, the colors reverse. what i've done so far: - global settings->graphics settings->chart trading primary = red, secondary = green - global settings->chart trade setting->display connecting lines, color connecting lines based on p/l: both checked - chart->graphics setting->use global setting, checked now, if i run a backtest, what should be green is red, and what should be red is green. i have to open global settings again and hit apply, then the color reverse to be ok. any idea? |
[2013-08-08 21:23:05] |
We will look this over.
[2013-08-10 16:42:56] |
Al SC Developer - Posts: 434 |
This will be addressed in ver 1009, when available.
