Date/Time: Sat, 18 May 2024 22:03:41 +0000
hello , I can not see the BR in the green circle.please see the screenshot
View Count: 579
[2017-01-18 05:20:08] |
User166767 - Posts: 32 |
I can not see the BR target in the green areas, can you tell what meaning the BR?please see the red circle. |
QQ截图20170117231934.png / V - Attached On 2017-01-18 05:20:03 UTC - Size: 17.97 KB - 208 views |
[2017-01-18 05:34:54] |
This is not supported with the particular data feed you are using. It is documented here: Status Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
