Date/Time: Sat, 18 May 2024 16:33:22 +0000
vs 1493
View Count: 691
[2017-01-17 21:00:55] |
Crtfyd - Posts: 277 |
Suggestion for future versions regarding Price Retracement Tool. Sometimes I need to see the price at the point I apply the tool (so price/percentage is on left) Sometimes I need to see when I am projected an hour or so past the time I apply the Price Retracement tool, so I check "Labels on Right". Sometimes though, I need BOTH. If the tool had "Check Labels on Right" AND "Check Labels on LEFT", it would give a clearer and more flexability to the set up. You wouldn't think this would matter much on the Main price chart as you can just put the curser to get the price the level is at, BUT, I put the retracement tool on studies like "Summation" on 1 second charts, so its hard to get the number the level is at without time consuming scrolling back to the place it was applied to see the levels. The only other solution would be to somehow when hovering over the line it would give its level, that would ensure a quick reference without scrolling left or right, but that sounds to me to be very arduous to code. FYI, THX |
[2017-01-18 04:49:47] |
Yes we can add an option to support the labels on both the left and right side of the Price Retracement drawings.
