Date/Time: Wed, 22 May 2024 00:24:14 +0000
[Programming Help] - Problem to put one value for each bar in the "DRAWSTYLE_VALUE_ON_HIGH"
View Count: 698
[2017-01-17 08:08:14] |
User210074 - Posts: 63 |
#include <windows.h> #include <math.h> #include <iostream> #include <stdio.h> #include <string.h> #include "sierrachart.h" using namespace std; SCDLLName("CDLSPE") double RoundTo( double Price){double Ra = round(Price * 100);double Rb = Ra/100;return Rb;}//round price double ColorCDLSPE(double OP, double CL){ double Res = CL-OP; if(Res>0){double Bg = 1;return Bg;} else if(Res == 0){double Bg = 0;return Bg;} else{double Bg = -1;return Bg;} }//end of ColorBg SCSFExport scsf_CDLSPE(SCStudyInterfaceRef sc) { int BarIndex = sc.Index; double SPA = sc.High[BarIndex];double SPB = sc.Low[BarIndex];double SPC = sc.Open[BarIndex];double SPD = sc.Close[BarIndex];double O = RoundTo(SPC);double C = RoundTo(SPD); SCSubgraphRef Type = sc.Subgraph[0]; if (sc.SetDefaults){ sc.GraphName = "Bougie"; sc.GraphRegion = 0; sc.AutoLoop = true; sc.FreeDLL = 1; Type.Name= "Type de bougie"; Type.DrawStyle = DRAWSTYLE_VALUE_ON_HIGH; Type.LineWidth = 1; Type.PrimaryColor = RGB(0,128,255); Type.DrawZeros = true; Type.GraphicalDisplacement= 1; return; }//end of defaults double BG = ColorCDLSPE(O,C); Type[BarIndex] = BG;//<--- probleme here }//end of CDLSPE Here, is the error message that I have in the "BUILD CUSTOM STUDY DLL" |
[2017-01-17 09:10:52] |
I forgot the error -- Starting build of Custom Studies Source files: CDLSPE.cpp. -- 09:00:31 C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat" C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" CDLSPE.cpp C:\SierraChart\ACS_Source\CDLSPE.cpp(35): warning C4244: '=': conversion from 'double' to 'float', possible loss of data Creating library CDLSPE.lib and object CDLSPE.exp Generating code Finished generating code -- End of Build -- 09:00:33 |
[2017-01-17 09:19:59] |
This is just a warning and not an error message. Looks like the building of the DLL was successful.
