Date/Time: Mon, 20 May 2024 23:53:58 +0000
IQfeed
View Count: 597
[2017-01-16 18:51:39] |
User11010 - Posts: 7 |
Please advise how I import my IQfeed into Sierra Cahrts--the only message I have is" IQfeed not supported with my Sierra package-which is same package I have used before
[2017-01-16 20:06:55] |
The problem is your Sierra Chart account is expired. We have activated it for 7 days. Here are the IQ Feed Setup instructions: http://www.sierrachart.com/index.php?page=doc/DTNIQFeed.html#Setup Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
