Date/Time: Tue, 21 May 2024 08:00:56 +0000
Included historical data
View Count: 633
[2017-01-16 17:16:33] |
User864777 - Posts: 2 |
Hi guys I am looking to use SC package 5 with out using real-time data feed. Is the historical data provided with SC good and reliable for profile charts? I think it is called SC Historical Data Service (From the symbols it looks like it is re-branded Barchart data) Many thanks |
[2017-01-16 19:38:20] |
Yes it is: Is the historical data provided with SC good and reliable for profile charts? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-16 20:40:10] |
Thanks very much for getting back so quickly. I got couple more questions. If you have got broker real time connection like CQG, would that mean the back fill still comes from SC Historical? IS SC Historical data feed similar to IQFEED/eSignal in quality and reliability? Once again Many thanks |
[2017-01-17 03:44:13] |
If you have got broker real time connection like CQG, would that mean the back fill still comes from SC Historical? IS SC Historical data feed similar to IQFEED/eSignal in quality and reliability? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
