Date/Time: Tue, 21 May 2024 20:32:14 +0000
SierraChart - Windows Error Code 6
View Count: 695
[2017-01-16 09:39:41] |
FerroTrader - Posts: 70 |
Hello, how can I solve the "Windows Error Code 6" that is keeping popping up like in the image here attached ? It's popping up since I upgraded to version 1506. thank you Andrew |
SC_error_popping.JPG / V - Attached On 2017-01-16 09:39:20 UTC - Size: 224.83 KB - 218 views |
[2017-01-16 10:08:54] |
Update to version 1507 with Help >> Download Prerelease.
