Date/Time: Tue, 21 May 2024 00:28:52 +0000
Windows Error
View Count: 648
[2017-01-16 04:22:33] |
Ziklag - Posts: 73 |
Hi, am yet to see whether the error below affects my trades but if I may ask in advance, what is causing it and how may I fix it ? ES.20170300.CME_Eq 5 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-01-16 07:04:27 * |
[2017-01-16 06:27:48] |
How often do you see this error? We do not know what is causing it. We made a change to limit the number of times it displays in the latest prerelease. It has no effect on trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
