Date/Time: Sun, 19 May 2024 15:10:30 +0000
hello ,I can not find the 1min ,5min,10min,30min,60min changing button,
View Count: 722
[2017-01-14 09:03:33] |
User166767 - Posts: 32 |
can you help me to find the 1min ,5min,10min,30min,60min candle button,can you tell me ?I can not find.I can not find the red circle .can you tell me how to find there?please see the screenshot.
QQ图片20170114030206.jpg / V - Attached On 2017-01-14 09:02:37 UTC - Size: 108.39 KB - 220 views |
[2017-01-14 09:29:50] |
You circled those buttons which change the bar period for Intraday charts so we are not understanding the question.
[2017-01-14 10:58:33] |
I have solved
