Date/Time: Sun, 19 May 2024 13:39:25 +0000
question about charting using ascil
View Count: 641
[2017-01-14 03:23:17] |
User103949 - Posts: 78 |
I am trying to draw additional lines above and below the bars. They are not straight lines. The values are changing with each bar generated. How can I add those two lines into the same chart with the OHLC bars?
[2017-01-14 11:18:17] |
This can be done by using ACSIL: Advanced Custom Study Interface and Language (ACSIL) You will need to set sc.GraphRegion = 0 in the code to draw in the main price graph region. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-14 15:54:17] |
Can this be done in one study or I need to create additional study?
[2017-01-14 20:36:34] |
We do not understand the question. It seems as though this is a question that you need to answer. Here is the relevant documentation: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
