Date/Time: Sun, 19 May 2024 14:54:51 +0000
spread trading with two symbols
View Count: 1142
[2017-01-13 22:23:57] |
stevenpaul - Posts: 9 |
Hello, Is it possible to use a "spreadsheet system for trading" to create a combo order comprised of two stocks (say SPY and QQQ), then trade such a combo as a single order? My goal is to create two-stock combos automatically using a spreadsheet, so I don't have to calculate the ratios by hand myself, then execute the newly created combo instrument as a single trade, limit order. Thank you! |
[2017-01-14 01:03:11] |
This is not possible using spreadsheets but it is possible using ACSIL: Automated Trading From an Advanced Custom Study However, this can only be done by submitting the two orders separately. ACSIL has the capability to submit orders for a symbol different than the chart the trading system study is on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-14 01:03:47
[2017-01-14 02:26:23] |
Sawtooth - Posts: 4000 |
I think it could be done with the Spreadsheet System for Trading study, but only as two simultaneous orders.
