Date/Time: Sun, 19 May 2024 09:23:02 +0000
30min ATR on 15min chart
View Count: 833
[2017-01-13 16:27:17] |
User565364 - Posts: 10 |
Hi my main chart is 15min, but I wanted to use ATR from 30min. Is there a way to do this without opening up a 30min chart and reference from that 30min chart? Thank you |
[2017-01-13 18:32:19] |
No there is not.
[2017-01-13 18:35:04] |
what about coding in ACSIL? is that possible?
[2017-01-14 11:16:46] |
Yes using ACSIL you could calculate the Average True Range for a 30 minute period by using the 15 minute bars. You have to work out the details of this though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
