Date/Time: Sun, 19 May 2024 05:07:10 +0000
moving multiple orders from the same price
View Count: 755
[2017-01-13 01:55:59] |
User144295 - Posts: 59 |
Hi Sierra team, sorry to bother you with trivial question. I haven't find the answer in the forum. When there are multiple orders at the same price like for example 2 stop loss orders, how can I move them with one click and one move without doing it one by one please? I have Stop orders in trade setup set as ALL OCO. Thank you |
[2017-01-13 03:47:55] |
I have Stop orders in trade setup set as ALL OCO. They may not in the version you are running. Update to the latest release and the problem will be resolved assuming this is the issue you are experiencing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-22 02:49:55] |
Thank you, it works. Just the short follow up question please. Assuming I open two positions. Each on different price. Later as profit grows I am moving both SL stop orders manually. Is there any way how to join these two SL stop orders later on, so I dont have to move twice with the mouse for each of them as I protect open profit? Thank you
[2017-01-22 09:07:18] |
No, this is not supported. Unless you started off using Scale In: Attached Orders: Scaling In Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
