Date/Time: Mon, 14 Jul 2025 21:09:06 +0000
Implementing simple trailing stop and profit target in ACSIL
View Count: 2662
[2017-01-12 18:45:31]
User514837 - Posts: 47
I am trying to simply enter the market using ACSIL, by using a simple trailing stop (let's say 10 ticks) and a target of 20 ticks. I don't want attached orders, because I think attached orders makes your orderquantity at least 2. Is the following doing what I would like to do? Simple trailing stop of 10 ticks and target profit of 20 ticks?
s_SCNewOrder NewOrder;
  NewOrder.OrderQuantity = 1;
  NewOrder.OrderType = SCT_ORDERTYPE_TRAILING_STOP;
  NewOrder.Price1 = sc.BaseData[SC_LAST][sc.Index] + 10*sc.TickSize;
  NewOrder.Target1Offset = 20 * sc.TickSize;
[2017-01-12 20:08:27]
Did you want to enter using a market order?
[2017-01-12 20:11:23]
By market order do you mean enter immediately at current market price? Then yes.
[2017-01-12 21:22:11]
Here is an example:
  NewOrder.OrderType = SCT_ORDERTYPE_MARKET;
  NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED;
  //Specify a Target and a Stop with 8 tick offsets. We are specifying one Target and one Stop, additional targets and stops can be specified as well.
  NewOrder.Target1Offset = 8*sc.TickSize;
  NewOrder.Stop1Offset = 8*sc.TickSize;
NewOrder.AttachedOrderStop1Type = SCT_ORDERTYPE_TRAILING_STOP;
  NewOrder.OCOGroup1Quantity = 1; // If this is left at the default of 0, then it will be automatically set.
You do need to use Attached Orders to put a Target and Stop. There is no other way.
Date Time Of Last Edit: 2017-01-12 21:58:58
[2017-01-12 21:24:10]
There's no trailing stop in the above code, I would be looking to have a trailing stop.
Date Time Of Last Edit: 2017-01-12 21:26:02
[2017-01-12 21:58:22]
We apologize for missing that detail. The code example is now updated.
[2017-01-16 13:31:22]
Keeping in mind I want a trailing stop, what is the difference between using the code that you recommended:
and
I see in backtests that using Price1 doesn't always hold, and trades don't get exited when they should. Is that the difference?
Date Time Of Last Edit: 2017-01-16 13:33:16
[2017-01-16 19:37:21]
The difference is that the second block of code is a trailing stop for the main order. And it has no attached Stop.
