Date/Time: Sun, 05 May 2024 16:38:52 +0000
[User Discussion] - Trade not going to Trade Activity Log
View Count: 1328
[2013-08-06 18:53:29] |
cloudchartist - Posts: 32 |
Hello I'm SIMing. For some reason my trades are showing up fine in Orders ad Positions but not going to the Trade Activity Log. Can you help? Thanks, Melissa |
[2013-08-06 19:02:52] |
Check the controls at the top of the Trade Activity Log to make sure they are set to show the trading activity and order fills for the particular trading activity that you want to see. Refer to the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-07 00:45:52] |
I checked everything I could and I still have no data.Also of note the lop left field that says "orders" can not be changed and is greyed out. |
