Date/Time: Sun, 19 May 2024 06:52:37 +0000
v1506 Volume At Price Threshold Alert V2 warning message
View Count: 828
[2017-01-11 15:34:31] |
vrunrun - Posts: 53 |
I got the following warning in message log and the message kept popping up when I tried to use the study. FYI, I used the input values of "Ask Volume Bid Volume Difference" and "Percentage Difference" under the input names "Comparison Method" and "Bid Ask Volume Comparison Method" respectively. "Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart." Pls check and revert. Thx. |
[2017-01-11 17:48:16] |
We will test this and resolve.
