Date/Time: Sun, 19 May 2024 07:52:03 +0000
CTS
View Count: 690
[2017-01-10 19:00:07] |
User536753 - Posts: 5 |
Hey Sierra. I signed up for Topstep Trader combine and it requires the CTS feed. I need help getting the feed to do the combine. Thanks |
[2017-01-10 22:48:32] |
You first will need a direct Sierra Chart account: Direct Sierra Chart Account And then you need to follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-10 23:39:25] |
Thanks for the quick reply. This poses some new questions: A direct account. I use AMP Futures. They give me free use of Sierra Charts. Does this not count as a direct account? If not, when I make a new account, will I have to pay for Sierra Charts usage? Or will my TST combine cover that? Are there any fees that I will have to pay for to get where I want to be? Thanks. |
[2017-01-11 00:23:19] |
The Sierra Chart account you are using is not a direct account and does not support CTS. Yes you will have to pay for Sierra Chart. Here is the pricing: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
