Date/Time: Tue, 14 May 2024 21:07:26 +0000
Auto Trade Stop Loss
View Count: 1333
[2017-01-09 17:21:10] |
User87521 - Posts: 81 |
I am sure this is a simple question but I am not finding a solution myself. I have an auto trade system that I would like to apply a stop loss. It can be dollar value or point value. I would prefer point I suppose. I have tried using J10 but the references keep getting screwed up. I have not found a study that would track trade profit/loss. (only day profit/loss) Any suggestions on applying a stop loss? Thanks. |
[2017-01-09 17:44:34] |
Refer to this section here about using Attached Orders: http://www.sierrachart.com/index.php?page=doc/SystemsAlerts.php#UsingManualOrAttachedOrdersExits Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-09 20:10:09] |
That's a nice option and I will likely implement it soon. Will it show up as a stopped out trade in back testing, or will the back testing only use the formulas in the spreadsheet.
[2017-01-09 20:44:52] |
Attached Orders do work during back testing as well.
[2017-01-09 21:06:08] |
Thank you.
[2017-01-09 21:29:40] |
Please do not say thank you and if you want to say thank you, this is why we added a Thank you button below a post that can be used instead.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-10 00:09:42
