Date/Time: Tue, 14 May 2024 06:22:12 +0000
REAL TIME
View Count: 609
[2017-01-09 15:35:30] |
User850017 - Posts: 41 |
Hi, My datafeed no stream REAL time. I have this datafeed and IB account. Where is a problem? I need SPX, RUT, NQ, DJA. Date Time Of Last Edit: 2017-01-09 15:37:19
[2017-01-09 18:43:33] |
None of those symbols you gave are valid symbols. You have only activated the CME and EUREX futures exchanges. So you can only work with futures symbols. You can find the correct symbols in File >> Find Symbol>> Futures. Also make sure you have connected to your Interactive Brokers account: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
