Date/Time: Sun, 05 May 2024 05:30:40 +0000
[User Discussion] - 3 day rolling pivot
View Count: 2671
[2013-08-06 14:19:00] |
User25261 - Posts: 24 |
HI, I need some help to program this pivot point formula. The formula is using the last 3 day's data(without counting the Sunday Data): the HLC/3 + HL/2 = Piv H the HLC/3 - HL/2 = Piv L It will be great if you can give help here:) Thanks in advance |
[2013-08-06 15:19:51] |
Sawtooth - Posts: 3993 |
This might do what you want: http://www.sawtoothtrade.com/free-stuff-3.html Date Time Of Last Edit: 2015-08-14 01:39:23
[2013-08-06 15:38:34] |
HI, I find one of your work here:ACD nrolling pivot. I dont know hoe to change the number of day?ex:10 or 15 ? Can you explain how i do it? Thanks |
[2013-08-06 15:46:12] |
In that study, the period days is set in cell H2 on the spreadsheet.
[2013-08-06 16:16:05] |
M5amhan - Posts: 468 |
3 day rolling pivots are also under "add custom study" they are called PPVP for 3 day aggregation (24h).. i remember seeing a thread about this
