Date/Time: Sat, 04 May 2024 18:17:06 +0000
Symbol display study
View Count: 915
[2017-01-07 23:13:08] |
Kinobe - Posts: 86 |
I think there is a bug with this study: I inserted this study for let's say AAPL was displayed. If I change the symbol, the display disappeares but if I put back AAPL, it re-appeares thank you |
[2017-01-07 23:22:37] |
We do not observe this. Make sure you have not entered that specific symbol into the study settings.
[2017-01-09 03:05:12] |
here is 3 pictures showing the problem I inserted the study with aapl I changed to anther symbol and the display disapears I changed nothing in the seetting - see picture. |
Symbol_display.jpg / V - Attached On 2017-01-09 03:03:34 UTC - Size: 293.29 KB - 239 views no_display.jpg / V - Attached On 2017-01-09 03:03:49 UTC - Size: 256.96 KB - 220 views Settings.jpg / V - Attached On 2017-01-09 03:03:59 UTC - Size: 191.74 KB - 252 views |
[2017-01-12 10:23:46] |
We still cannot reproduce the problem. Not sure if this is going to help but remove the study from the chart and then add it again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-20 02:36:34] |
I found that If I checked the case "Show chart drawings for differents symbols" the symbol name remains displayed when I change the stock ...but I have as well all lines of all stocks I drwaned before... :-( could it be possible to get the symbol display without having all line of differents stock? |
[2017-01-20 03:18:11] |
OK we understand the reason for the problem now. This will be solved in the next release.
