Date/Time: Tue, 30 Apr 2024 05:11:35 +0000
Incorrect bar range with CTS FIX
View Count: 2097
[2013-08-06 14:03:32] |
MMX - Posts: 119 |
This past weekend I upgraded from v993 to v1004. Yesterday before 7am, I was suspicious of the large size of a single bar (5 min chart) in the Euro and in the Yen. I deleted and downloaded from a few bars back and the 2 bars in question returned to a "normal" size. In the case of the Euro, this was a 20 tick difference in bar size. Then at 9am, just after the ISM report, the Euro did the same thing again. I upgraded to v1005 yesterday afternoon hoping that might fix the problem. It didn't. Today, I had a wrong sized bar in Crude and again in the Euro. These are not 1 or 2 tick differences, these are 20 to 30 tick differences in bar size.
[2013-08-06 14:24:38] |
MMX - Posts: 119 |
Just this instant, the Euro was reduced from a 52 tick bar to a 24 tick bar after deleting and downloading.
[2013-08-06 18:03:15] |
Go to Edit >> Edit/Download Data-Intraday Chart and look at the data records for the bars in question and see if you can tell a problem with the Date-Time values. There must be some problem with the Date-Times. For example the Date-Times are not changing.
[2013-08-06 19:15:32] |
MMX - Posts: 119 |
I looked, I didn't see anything. Wouldn't the delete and download, which was done at the time it happened, re-write the record anyway? When messing with the Edit/Download Data dialog box, in an effort to speed things up, I entered the time I wanted in the time box and the message below popped up: Well, that didn't work out. I thought I was only copying the last 10 or 15 lines of the log. But I'm going to send the whole log anyway because every since installing CTS FIX I've been getting hit with a lot of message logs, mostly along these lines: "CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-06 06:51:46 CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-06 06:51:46". Maybe something will be revealed in the info below. There were probably 5 or 6 instances today where substantially incorrect bars were printed (Crude, Euro, Yen), probably 4 or 5 yesterday. Software version: 1005 | 2013-08-06 06:50:28 Current Service Package: 3 | 2013-08-06 06:50:28 Usage end date: 2013-08-27 | 2013-08-06 06:50:28 Sierra Chart Historical Data Service is included. | 2013-08-06 06:50:28 Active service: CTS T4 | 2013-08-06 06:50:28 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-08-06 06:50:28 2013-08-06 06:50:28 Local computer clock time | 2013-08-06 06:50:28 2013-08-06 11:50:28 GMT time | 2013-08-06 06:50:28 2013-08-06 06:50:28 Time zone adjusted time | 2013-08-06 06:50:28 Time difference to server time: 2 seconds. | 2013-08-06 06:50:28 Program path: C:\SierraChart\ | 2013-08-06 06:50:28 Data Files path: C:\SierraChart\Data\ | 2013-08-06 06:50:28 OS Version Number: 6.1 | 2013-08-06 06:50:28 HD Request # 1 - Downloading Historical Daily chart data for NGU13. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:56 HD Request # 1 - Requesting historical Daily data for NGU13 starting at 2013-08-04 | 2013-08-06 06:50:56 HD Request # 1 - Receiving historical Daily data for NGU13 starting at 2013-08-05 | 2013-08-06 06:50:56 Writing historical daily data for NGU13 to the file NGU13.dly | 2013-08-06 06:50:56 HD Request # 1 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for NGU13 | 2013-08-06 06:50:56 HD Request # 1 - Daily download COMPLETE for NGU13 | 2013-08-06 06:50:56 HD Request # 2 - Downloading Historical Daily chart data for NG#. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:56 HD Request # 2 - Requesting historical Daily Continuous data for NGZ10 starting at 2013-08-04 | 2013-08-06 06:50:56 HD Request # 2 - Receiving historical Daily data for NG# starting at 2013-08-05 | 2013-08-06 06:50:56 Writing historical daily data for NG# to the file NG#.dly | 2013-08-06 06:50:56 HD Request # 2 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for NG# | 2013-08-06 06:50:56 HD Request # 2 - Daily download COMPLETE for NG# | 2013-08-06 06:50:56 HD Request # 3 - Downloading Historical Daily chart data for CLU13. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:56 HD Request # 3 - Requesting historical Daily data for CLU13 starting at 2013-08-04 | 2013-08-06 06:50:56 HD Request # 3 - Receiving historical Daily data for CLU13 starting at 2013-08-05 | 2013-08-06 06:50:56 Writing historical daily data for CLU13 to the file CLU13.dly | 2013-08-06 06:50:56 HD Request # 3 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for CLU13 | 2013-08-06 06:50:56 HD Request # 3 - Daily download COMPLETE for CLU13 | 2013-08-06 06:50:56 HD Request # 4 - Downloading Historical Daily chart data for CL#. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:56 HD Request # 4 - Requesting historical Daily Continuous data for CLZ10 starting at 2013-08-04 | 2013-08-06 06:50:56 HD Request # 4 - Receiving historical Daily data for CL# starting at 2013-08-05 | 2013-08-06 06:50:56 Writing historical daily data for CL# to the file CL#.dly | 2013-08-06 06:50:56 HD Request # 4 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for CL# | 2013-08-06 06:50:56 HD Request # 4 - Daily download COMPLETE for CL# | 2013-08-06 06:50:56 HD Request # 5 - Downloading Historical Daily chart data for E6#. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:56 HD Request # 5 - Requesting historical Daily Continuous data for E6Z10 starting at 2013-08-04 | 2013-08-06 06:50:56 HD Request # 5 - Receiving historical Daily data for E6# starting at 2013-08-05 | 2013-08-06 06:50:56 Writing historical daily data for E6# to the file E6#.dly | 2013-08-06 06:50:56 HD Request # 5 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for E6# | 2013-08-06 06:50:57 HD Request # 5 - Daily download COMPLETE for E6# | 2013-08-06 06:50:57 HD Request # 6 - Downloading Historical Daily chart data for J6U13. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:57 HD Request # 6 - Requesting historical Daily data for J6U13 starting at 2013-08-04 | 2013-08-06 06:50:57 HD Request # 6 - Receiving historical Daily data for J6U13 starting at 2013-08-05 | 2013-08-06 06:50:57 Writing historical daily data for J6U13 to the file J6U13.dly | 2013-08-06 06:50:57 HD Request # 6 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for J6U13 | 2013-08-06 06:50:57 HD Request # 6 - Daily download COMPLETE for J6U13 | 2013-08-06 06:50:57 HD Request # 7 - Downloading Historical Daily chart data for J6#. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:57 HD Request # 7 - Requesting historical Daily Continuous data for J6Z10 starting at 2013-08-04 | 2013-08-06 06:50:57 HD Request # 7 - Receiving historical Daily data for J6# starting at 2013-08-05 | 2013-08-06 06:50:57 Writing historical daily data for J6# to the file J6#.dly | 2013-08-06 06:50:57 HD Request # 7 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for J6# | 2013-08-06 06:50:57 HD Request # 7 - Daily download COMPLETE for J6# | 2013-08-06 06:50:57 HD Request # 8 - Downloading Historical Daily chart data for E6U13. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:57 HD Request # 8 - Requesting historical Daily data for E6U13 starting at 2013-08-04 | 2013-08-06 06:50:57 HD Request # 8 - Receiving historical Daily data for E6U13 starting at 2013-08-05 | 2013-08-06 06:50:57 Writing historical daily data for E6U13 to the file E6U13.dly | 2013-08-06 06:50:57 HD Request # 8 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for E6U13 | 2013-08-06 06:50:57 HD Request # 8 - Daily download COMPLETE for E6U13 | 2013-08-06 06:50:57 HD Request # 9 - Downloading Historical Daily chart data for HGU13. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:57 HD Request # 9 - Requesting historical Daily data for HGU13 starting at 2013-08-04 | 2013-08-06 06:50:57 Connecting to CTS Live server. | 2013-08-06 06:50:57 CTS FIX - Connecting to data and trade server: fix.t4login.com | 2013-08-06 06:50:57 HD Request # 9 - Receiving historical Daily data for HGU13 starting at 2013-08-05 | 2013-08-06 06:50:57 Writing historical daily data for HGU13 to the file HGU13.dly | 2013-08-06 06:50:57 HD Request # 9 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for HGU13 | 2013-08-06 06:50:57 HD Request # 9 - Daily download COMPLETE for HGU13 | 2013-08-06 06:50:57 HD Request # 10 - Downloading Historical Daily chart data for GCZ13. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:57 HD Request # 10 - Requesting historical Daily data for GCZ13 starting at 2013-08-04 | 2013-08-06 06:50:57 The network socket is connected. | 2013-08-06 06:50:57 The socket starting SSL connection. | 2013-08-06 06:50:57 HD Request # 10 - Receiving historical Daily data for GCZ13 starting at 2013-08-05 | 2013-08-06 06:50:57 Writing historical daily data for GCZ13 to the file GCZ13.dly | 2013-08-06 06:50:57 HD Request # 10 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for GCZ13 | 2013-08-06 06:50:57 HD Request # 10 - Daily download COMPLETE for GCZ13 | 2013-08-06 06:50:57 HD Request # 11 - Downloading Historical Daily chart data for HG#. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:57 HD Request # 11 - Requesting historical Daily Continuous data for HGZ10 starting at 2013-08-04 | 2013-08-06 06:50:57 HD Request # 11 - Receiving historical Daily data for HG# starting at 2013-08-05 | 2013-08-06 06:50:57 Writing historical daily data for HG# to the file HG#.dly | 2013-08-06 06:50:57 HD Request # 11 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for HG# | 2013-08-06 06:50:57 HD Request # 11 - Daily download COMPLETE for HG# | 2013-08-06 06:50:57 HD Request # 12 - Downloading Historical Daily chart data for ZB#. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:57 HD Request # 12 - Requesting historical Daily Continuous data for ZBZ10 starting at 2013-08-04 | 2013-08-06 06:50:57 SSL socket is now connected. | 2013-08-06 06:50:57 CTS FIX: Sending the Logon message. | 2013-08-06 06:50:57 HD Request # 12 - Receiving historical Daily data for ZB# starting at 2013-08-05 | 2013-08-06 06:50:58 Writing historical daily data for ZB# to the file ZB#.dly | 2013-08-06 06:50:58 HD Request # 12 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for ZB# | 2013-08-06 06:50:58 HD Request # 12 - Daily download COMPLETE for ZB# | 2013-08-06 06:50:58 HD Request # 13 - Downloading Historical Daily chart data for ZBU13. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:58 HD Request # 13 - Requesting historical Daily data for ZBU13 starting at 2013-08-04 | 2013-08-06 06:50:58 HD Request # 13 - Receiving historical Daily data for ZBU13 starting at 2013-08-05 | 2013-08-06 06:50:58 Writing historical daily data for ZBU13 to the file ZBU13.dly | 2013-08-06 06:50:58 HD Request # 13 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for ZBU13 | 2013-08-06 06:50:58 HD Request # 13 - Daily download COMPLETE for ZBU13 | 2013-08-06 06:50:58 HD Request # 14 - Downloading Historical Daily chart data for ESU13. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:58 HD Request # 14 - Requesting historical Daily data for ESU13 starting at 2013-08-04 | 2013-08-06 06:50:58 HD Request # 14 - Receiving historical Daily data for ESU13 starting at 2013-08-05 | 2013-08-06 06:50:58 Writing historical daily data for ESU13 to the file ESU13.dly | 2013-08-06 06:50:58 HD Request # 14 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for ESU13 | 2013-08-06 06:50:58 HD Request # 14 - Daily download COMPLETE for ESU13 | 2013-08-06 06:50:58 HD Request # 15 - Downloading Historical Daily chart data for ES#. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:58 HD Request # 15 - Requesting historical Daily Continuous data for ESZ10 starting at 2013-08-04 | 2013-08-06 06:50:58 HD Request # 15 - Receiving historical Daily data for ES# starting at 2013-08-05 | 2013-08-06 06:50:58 Writing historical daily data for ES# to the file ES#.dly | 2013-08-06 06:50:58 HD Request # 15 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for ES# | 2013-08-06 06:50:58 HD Request # 15 - Daily download COMPLETE for ES# | 2013-08-06 06:50:58 HD Request # 16 - Downloading Historical Daily chart data for GC#. Starting date: 2013-08-05. Service: ddf | 2013-08-06 06:50:58 HD Request # 16 - Requesting historical Daily Continuous data for GCZ10 starting at 2013-08-04 | 2013-08-06 06:50:58 HD Request # 16 - Receiving historical Daily data for GC# starting at 2013-08-05 | 2013-08-06 06:50:58 Writing historical daily data for GC# to the file GC#.dly | 2013-08-06 06:50:58 HD Request # 16 - Received 2 records from 2013-08-05 00:00:00 to 2013-08-06 00:00:00 (2.0 days) and wrote 2 records for GC# | 2013-08-06 06:50:58 HD Request # 16 - Daily download COMPLETE for GC# | 2013-08-06 06:50:58 CTS FIX: Connected. | 2013-08-06 06:50:58 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 06:50:58 Error connecting socket: Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-08-06 06:51:19 CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-06 06:51:19 CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-06 06:51:19 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 06:51:24 Error connecting socket: Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-08-06 06:51:46 CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-06 06:51:46 CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-06 06:51:46 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 06:51:51 Connection timed out. Will disconnect and retry. | 2013-08-06 06:51:57 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-06 06:51:57 To prevent further connection attempts, select File >> Disconnect. | 2013-08-06 06:51:57 CTS FIX: Sending a Logout message. | 2013-08-06 06:51:57 CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-06 06:51:57 CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-06 06:51:57 CTS FIX: Disconnected. | 2013-08-06 06:51:57 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-08-06 06:51:57 CTS FIX: Received a Logout message. Text = Successful logout upon request | 2013-08-06 06:51:57 The SSL socket was shut down successfully. | 2013-08-06 06:51:57 CTS FIX: Logged out and disconnected. | 2013-08-06 06:51:57 Ignored socket Close call based on current socket state. | 2013-08-06 06:51:57 Connecting to CTS Live server. | 2013-08-06 06:52:02 CTS FIX - Connecting to data and trade server: fix.t4login.com | 2013-08-06 06:52:02 The network socket is connected. | 2013-08-06 06:52:02 The socket starting SSL connection. | 2013-08-06 06:52:02 SSL socket is now connected. | 2013-08-06 06:52:02 CTS FIX: Sending the Logon message. | 2013-08-06 06:52:02 CTS FIX: Connected. | 2013-08-06 06:52:03 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 06:52:03 Error connecting socket: Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-08-06 06:52:24 CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-06 06:52:24 CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-06 06:52:24 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 06:52:29 Error connecting socket: Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-08-06 06:52:50 CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-06 06:52:50 CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-06 06:52:50 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 06:52:55 The network socket is connected. | 2013-08-06 06:52:55 The socket starting SSL connection. | 2013-08-06 06:52:55 SSL socket is now connected. | 2013-08-06 06:52:56 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 06:52:56 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 06:52:57 CTS FIX: Fully connected. | 2013-08-06 06:52:57 Starting updates for: ES.CME_20130900_ESU3.CME_Eq | 2013-08-06 06:52:57 Starting updates for: HG.CME_20130900_HGU3.CME_CO | 2013-08-06 06:52:57 Starting updates for: 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 06:52:57 Starting updates for: 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 06:52:57 HD Request # 17 - Downloading Intraday chart data for 6E.CME_20130900_6EU3.CME_Fo to the file 6E.CME_20130900_6EU3.CME_Fo.scid. Service: cts | 2013-08-06 06:52:57 HD Request # 17 - Starting date and time: 2013-08-05 21:05:17.0 | 2013-08-06 06:52:57 HD Request # 17 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-04 to 2013-08-05 | 2013-08-06 06:52:57 Starting updates for: NG.CME_20130900_NGU3.CME_NY | 2013-08-06 06:52:57 Starting updates for: CL.CME_20130900_CLU3.CME_NY | 2013-08-06 06:52:57 Starting updates for: GC.CME_20131200_GCZ3.CME_CO | 2013-08-06 06:52:57 Starting updates for: ZB.CME_20130900_ZBU3.CME_F | 2013-08-06 06:52:57 HD Request # 17 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-05 to 2013-08-06 | 2013-08-06 06:52:57 SYMBOL DEF: 8=FIX.4.29=25035=d34=12949=Vision56=SierraChart50=T4FIX52=20130806-11:52:58.864320=S2525776322=sd-8/6/2013 6:52:58 AM323=4911=155=NG107=Natural Gas Sep1348=CME_20130900_NGU340=146351207=CME_NY200=20130900167=FUT762=0562=115=USD1146=105770=1/110=019 | 2013-08-06 06:52:57 HD Request # 17 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-06 to 2013-08-07 | 2013-08-06 06:52:59 HD Request # 17 - Timestamp of first Intraday data file record written: 2013-08-05 21:05:17 | 2013-08-06 06:53:00 HD Request # 17 - Received 139476 records and wrote 39085 records for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 06:53:00 HD Request # 17 - Intraday download COMPLETE for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 06:53:00 Real-time intraday chart data file updates started for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 06:53:00 HD Request # 18 - Downloading Intraday chart data for 6J.CME_20130900_6JU3.CME_Fo to the file 6J.CME_20130900_6JU3.CME_Fo.scid. Service: cts | 2013-08-06 06:53:00 HD Request # 18 - Starting date and time: 2013-08-05 21:05:30.0 | 2013-08-06 06:53:00 HD Request # 18 - Requesting historical Tick data for 6J.CME_20130900_6JU3.CME_Fo from 2013-08-04 to 2013-08-05 | 2013-08-06 06:53:00 HD Request # 18 - Requesting historical Tick data for 6J.CME_20130900_6JU3.CME_Fo from 2013-08-05 to 2013-08-06 | 2013-08-06 06:53:00 HD Request # 18 - Requesting historical Tick data for 6J.CME_20130900_6JU3.CME_Fo from 2013-08-06 to 2013-08-07 | 2013-08-06 06:53:02 HD Request # 18 - Timestamp of first Intraday data file record written: 2013-08-05 21:05:30 | 2013-08-06 06:53:02 HD Request # 18 - Received 96542 records and wrote 25870 records for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 06:53:03 HD Request # 18 - Intraday download COMPLETE for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 06:53:03 Real-time intraday chart data file updates started for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 06:53:03 HD Request # 19 - Downloading Intraday chart data for HG.CME_20130900_HGU3.CME_CO to the file HG.CME_20130900_HGU3.CME_CO.scid. Service: cts | 2013-08-06 06:53:03 HD Request # 19 - Starting date and time: 2013-08-05 21:05:02.0 | 2013-08-06 06:53:03 HD Request # 19 - Requesting historical Tick data for HG.CME_20130900_HGU3.CME_CO from 2013-08-04 to 2013-08-05 | 2013-08-06 06:53:03 HD Request # 19 - Requesting historical Tick data for HG.CME_20130900_HGU3.CME_CO from 2013-08-05 to 2013-08-06 | 2013-08-06 06:53:03 HD Request # 19 - Requesting historical Tick data for HG.CME_20130900_HGU3.CME_CO from 2013-08-06 to 2013-08-07 | 2013-08-06 06:53:03 HD Request # 19 - Timestamp of first Intraday data file record written: 2013-08-05 21:05:02 | 2013-08-06 06:53:04 HD Request # 19 - Received 38757 records and wrote 12639 records for HG.CME_20130900_HGU3.CME_CO | 2013-08-06 06:53:04 HD Request # 19 - Intraday download COMPLETE for HG.CME_20130900_HGU3.CME_CO | 2013-08-06 06:53:04 Real-time intraday chart data file updates started for HG.CME_20130900_HGU3.CME_CO | 2013-08-06 06:53:04 HD Request # 20 - Downloading Intraday chart data for NG.CME_20130900_NGU3.CME_NY to the file NG.CME_20130900_NGU3.CME_NY.scid. Service: cts | 2013-08-06 06:53:04 HD Request # 20 - Starting date and time: 2013-08-05 21:02:48.0 | 2013-08-06 06:53:04 HD Request # 20 - Requesting historical Tick data for NG.CME_20130900_NGU3.CME_NY from 2013-08-04 to 2013-08-05 | 2013-08-06 06:53:04 HD Request # 20 - Requesting historical Tick data for NG.CME_20130900_NGU3.CME_NY from 2013-08-05 to 2013-08-06 | 2013-08-06 06:53:04 HD Request # 20 - Requesting historical Tick data for NG.CME_20130900_NGU3.CME_NY from 2013-08-06 to 2013-08-07 | 2013-08-06 06:53:05 HD Request # 20 - Timestamp of first Intraday data file record written: 2013-08-05 21:02:48 | 2013-08-06 06:53:05 HD Request # 20 - Received 39768 records and wrote 3156 records for NG.CME_20130900_NGU3.CME_NY | 2013-08-06 06:53:05 HD Request # 20 - Intraday download COMPLETE for NG.CME_20130900_NGU3.CME_NY | 2013-08-06 06:53:05 Real-time intraday chart data file updates started for NG.CME_20130900_NGU3.CME_NY | 2013-08-06 06:53:05 HD Request # 21 - Downloading Intraday chart data for ES.CME_20130900_ESU3.CME_Eq to the file ES.CME_20130900_ESU3.CME_Eq.scid. Service: cts | 2013-08-06 06:53:05 HD Request # 21 - Starting date and time: 2013-08-05 21:05:29.0 | 2013-08-06 06:53:05 HD Request # 21 - Requesting historical Tick data for ES.CME_20130900_ESU3.CME_Eq from 2013-08-04 to 2013-08-05 | 2013-08-06 06:53:05 HD Request # 21 - Requesting historical Tick data for ES.CME_20130900_ESU3.CME_Eq from 2013-08-05 to 2013-08-06 | 2013-08-06 06:53:05 HD Request # 21 - Requesting historical Tick data for ES.CME_20130900_ESU3.CME_Eq from 2013-08-06 to 2013-08-07 | 2013-08-06 06:53:10 HD Request # 21 - Timestamp of first Intraday data file record written: 2013-08-05 21:05:29 | 2013-08-06 06:53:11 HD Request # 21 - Received 277702 records and wrote 29581 records for ES.CME_20130900_ESU3.CME_Eq | 2013-08-06 06:53:11 HD Request # 21 - Intraday download COMPLETE for ES.CME_20130900_ESU3.CME_Eq | 2013-08-06 06:53:11 Real-time intraday chart data file updates started for ES.CME_20130900_ESU3.CME_Eq | 2013-08-06 06:53:11 HD Request # 22 - Downloading Intraday chart data for CL.CME_20130900_CLU3.CME_NY to the file CL.CME_20130900_CLU3.CME_NY.scid. Service: cts | 2013-08-06 06:53:11 HD Request # 22 - Starting date and time: 2013-08-05 21:05:26.0 | 2013-08-06 06:53:11 HD Request # 22 - Requesting historical Tick data for CL.CME_20130900_CLU3.CME_NY from 2013-08-04 to 2013-08-05 | 2013-08-06 06:53:11 HD Request # 22 - Requesting historical Tick data for CL.CME_20130900_CLU3.CME_NY from 2013-08-05 to 2013-08-06 | 2013-08-06 06:53:11 HD Request # 22 - Requesting historical Tick data for CL.CME_20130900_CLU3.CME_NY from 2013-08-06 to 2013-08-07 | 2013-08-06 06:53:14 HD Request # 22 - Timestamp of first Intraday data file record written: 2013-08-05 21:05:26 | 2013-08-06 06:53:15 HD Request # 22 - Received 140232 records and wrote 22945 records for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 06:53:15 HD Request # 22 - Intraday download COMPLETE for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 06:53:15 Real-time intraday chart data file updates started for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 06:53:15 HD Request # 23 - Downloading Intraday chart data for GC.CME_20131200_GCZ3.CME_CO to the file GC.CME_20131200_GCZ3.CME_CO.scid. Service: cts | 2013-08-06 06:53:15 HD Request # 23 - Starting date and time: 2013-08-05 21:05:20.0 | 2013-08-06 06:53:15 HD Request # 23 - Requesting historical Tick data for GC.CME_20131200_GCZ3.CME_CO from 2013-08-04 to 2013-08-05 | 2013-08-06 06:53:15 HD Request # 23 - Requesting historical Tick data for GC.CME_20131200_GCZ3.CME_CO from 2013-08-05 to 2013-08-06 | 2013-08-06 06:53:15 HD Request # 23 - Requesting historical Tick data for GC.CME_20131200_GCZ3.CME_CO from 2013-08-06 to 2013-08-07 | 2013-08-06 06:53:17 HD Request # 23 - Timestamp of first Intraday data file record written: 2013-08-05 21:05:20 | 2013-08-06 06:53:18 HD Request # 23 - Received 113585 records and wrote 37261 records for GC.CME_20131200_GCZ3.CME_CO | 2013-08-06 06:53:19 HD Request # 23 - Intraday download COMPLETE for GC.CME_20131200_GCZ3.CME_CO | 2013-08-06 06:53:19 Real-time intraday chart data file updates started for GC.CME_20131200_GCZ3.CME_CO | 2013-08-06 06:53:19 HD Request # 24 - Downloading Intraday chart data for ZB.CME_20130900_ZBU3.CME_F to the file ZB.CME_20130900_ZBU3.CME_F.scid. Service: cts | 2013-08-06 06:53:19 HD Request # 24 - Starting date and time: 2013-08-05 21:05:02.0 | 2013-08-06 06:53:19 HD Request # 24 - Requesting historical Tick data for ZB.CME_20130900_ZBU3.CME_F from 2013-08-04 to 2013-08-05 | 2013-08-06 06:53:19 HD Request # 24 - Requesting historical Tick data for ZB.CME_20130900_ZBU3.CME_F from 2013-08-05 to 2013-08-06 | 2013-08-06 06:53:19 HD Request # 24 - Requesting historical Tick data for ZB.CME_20130900_ZBU3.CME_F from 2013-08-06 to 2013-08-07 | 2013-08-06 06:53:20 HD Request # 24 - Timestamp of first Intraday data file record written: 2013-08-05 21:05:02 | 2013-08-06 06:53:20 HD Request # 24 - Received 69769 records and wrote 8027 records for ZB.CME_20130900_ZBU3.CME_F | 2013-08-06 06:53:20 HD Request # 24 - Intraday download COMPLETE for ZB.CME_20130900_ZBU3.CME_F | 2013-08-06 06:53:20 Real-time intraday chart data file updates started for ZB.CME_20130900_ZBU3.CME_F | 2013-08-06 06:53:20 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 06:54:20 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 06:54:20 The SSL socket was shut down successfully. | 2013-08-06 06:54:20 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 06:54:20 CTS Historical FIX Session: Disconnected. | 2013-08-06 06:54:20 Ignored socket Close call based on current socket state. | 2013-08-06 06:54:20 HD Request # 25 - Downloading Intraday chart data for 6E.CME_20130900_6EU3.CME_Fo to the file 6E.CME_20130900_6EU3.CME_Fo.scid. Service: cts | 2013-08-06 08:17:06 HD Request # 25 - Starting date and time: 2013-08-06 06:59:56.0 | 2013-08-06 08:17:06 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 08:17:06 The network socket is connected. | 2013-08-06 08:17:06 The socket starting SSL connection. | 2013-08-06 08:17:06 SSL socket is now connected. | 2013-08-06 08:17:06 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 08:17:06 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 08:17:07 HD Request # 25 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-05 to 2013-08-06 | 2013-08-06 08:17:07 HD Request # 25 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-06 to 2013-08-07 | 2013-08-06 08:17:09 HD Request # 25 - Timestamp of first Intraday data file record written: 2013-08-06 06:59:56 | 2013-08-06 08:17:10 HD Request # 25 - Received 162419 records and wrote 22205 records for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 08:17:11 HD Request # 25 - Intraday download COMPLETE for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 08:17:11 Real-time intraday chart data file updates started for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 08:17:11 HD Request # 26 - Downloading Intraday chart data for 6J.CME_20130900_6JU3.CME_Fo to the file 6J.CME_20130900_6JU3.CME_Fo.scid. Service: cts | 2013-08-06 08:17:41 HD Request # 26 - Starting date and time: 2013-08-06 06:59:58.0 | 2013-08-06 08:17:41 HD Request # 26 - Requesting historical Tick data for 6J.CME_20130900_6JU3.CME_Fo from 2013-08-05 to 2013-08-06 | 2013-08-06 08:17:41 HD Request # 26 - Requesting historical Tick data for 6J.CME_20130900_6JU3.CME_Fo from 2013-08-06 to 2013-08-07 | 2013-08-06 08:17:43 HD Request # 26 - Timestamp of first Intraday data file record written: 2013-08-06 06:59:58 | 2013-08-06 08:17:44 HD Request # 26 - Received 101682 records and wrote 4974 records for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 08:17:44 HD Request # 26 - Intraday download COMPLETE for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 08:17:44 Real-time intraday chart data file updates started for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 08:17:44 HD Request # 27 - Downloading Intraday chart data for CL.CME_20130900_CLU3.CME_NY to the file CL.CME_20130900_CLU3.CME_NY.scid. Service: cts | 2013-08-06 08:18:21 HD Request # 27 - Starting date and time: 2013-08-06 07:29:58.0 | 2013-08-06 08:18:21 HD Request # 27 - Requesting historical Tick data for CL.CME_20130900_CLU3.CME_NY from 2013-08-05 to 2013-08-06 | 2013-08-06 08:18:21 HD Request # 27 - Requesting historical Tick data for CL.CME_20130900_CLU3.CME_NY from 2013-08-06 to 2013-08-07 | 2013-08-06 08:18:24 HD Request # 27 - Timestamp of first Intraday data file record written: 2013-08-06 07:29:58 | 2013-08-06 08:18:25 HD Request # 27 - Received 157544 records and wrote 14346 records for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 08:18:25 HD Request # 27 - Intraday download COMPLETE for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 08:18:25 Real-time intraday chart data file updates started for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 08:18:25 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 08:19:24 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 08:19:24 The SSL socket was shut down successfully. | 2013-08-06 08:19:24 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 08:19:24 CTS Historical FIX Session: Disconnected. | 2013-08-06 08:19:24 Ignored socket Close call based on current socket state. | 2013-08-06 08:19:24 HD Request # 28 - Downloading Intraday chart data for HG.CME_20130900_HGU3.CME_CO to the file HG.CME_20130900_HGU3.CME_CO.scid. Service: cts | 2013-08-06 08:19:50 HD Request # 28 - Starting date and time: 2013-08-06 07:24:59.0 | 2013-08-06 08:19:50 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 08:19:50 The network socket is connected. | 2013-08-06 08:19:50 The socket starting SSL connection. | 2013-08-06 08:19:50 SSL socket is now connected. | 2013-08-06 08:19:50 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 08:19:50 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 08:19:51 HD Request # 28 - Requesting historical Tick data for HG.CME_20130900_HGU3.CME_CO from 2013-08-05 to 2013-08-06 | 2013-08-06 08:19:51 HD Request # 28 - Requesting historical Tick data for HG.CME_20130900_HGU3.CME_CO from 2013-08-06 to 2013-08-07 | 2013-08-06 08:19:52 HD Request # 28 - Timestamp of first Intraday data file record written: 2013-08-06 07:24:59 | 2013-08-06 08:19:53 HD Request # 28 - Received 43109 records and wrote 2668 records for HG.CME_20130900_HGU3.CME_CO | 2013-08-06 08:19:53 HD Request # 28 - Intraday download COMPLETE for HG.CME_20130900_HGU3.CME_CO | 2013-08-06 08:19:53 Real-time intraday chart data file updates started for HG.CME_20130900_HGU3.CME_CO | 2013-08-06 08:19:53 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 08:20:52 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 08:20:52 The SSL socket was shut down successfully. | 2013-08-06 08:20:52 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 08:20:52 CTS Historical FIX Session: Disconnected. | 2013-08-06 08:20:52 Ignored socket Close call based on current socket state. | 2013-08-06 08:20:52 HD Request # 29 - Downloading Intraday chart data for CL.CME_20130900_CLU3.CME_NY to the file CL.CME_20130900_CLU3.CME_NY.scid. Service: cts | 2013-08-06 08:22:57 HD Request # 29 - Starting date and time: 2013-08-06 03:14:47.0 | 2013-08-06 08:22:57 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 08:22:57 The network socket is connected. | 2013-08-06 08:22:58 The socket starting SSL connection. | 2013-08-06 08:22:58 SSL socket is now connected. | 2013-08-06 08:22:58 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 08:22:58 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 08:22:59 HD Request # 29 - Requesting historical Tick data for CL.CME_20130900_CLU3.CME_NY from 2013-08-05 to 2013-08-06 | 2013-08-06 08:22:59 HD Request # 29 - Requesting historical Tick data for CL.CME_20130900_CLU3.CME_NY from 2013-08-06 to 2013-08-07 | 2013-08-06 08:23:01 HD Request # 29 - Timestamp of first Intraday data file record written: 2013-08-06 03:14:47 | 2013-08-06 08:23:03 HD Request # 29 - Received 158696 records and wrote 33717 records for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 08:23:03 HD Request # 29 - Intraday download COMPLETE for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 08:23:03 Real-time intraday chart data file updates started for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 08:23:03 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 08:24:02 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 08:24:02 The SSL socket was shut down successfully. | 2013-08-06 08:24:02 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 08:24:02 CTS Historical FIX Session: Disconnected. | 2013-08-06 08:24:02 Ignored socket Close call based on current socket state. | 2013-08-06 08:24:02 HD Request # 30 - Downloading Intraday chart data for 6E.CME_20130900_6EU3.CME_Fo to the file 6E.CME_20130900_6EU3.CME_Fo.scid. Service: cts | 2013-08-06 09:20:59 HD Request # 30 - Starting date and time: 2013-08-06 08:54:54.0 | 2013-08-06 09:20:59 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 09:20:59 The network socket is connected. | 2013-08-06 09:21:00 The socket starting SSL connection. | 2013-08-06 09:21:00 SSL socket is now connected. | 2013-08-06 09:21:00 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 09:21:00 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 09:21:01 HD Request # 30 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-05 to 2013-08-06 | 2013-08-06 09:21:01 HD Request # 30 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-06 to 2013-08-07 | 2013-08-06 09:21:03 HD Request # 30 - Timestamp of first Intraday data file record written: 2013-08-06 08:54:54 | 2013-08-06 09:21:05 HD Request # 30 - Received 179024 records and wrote 9818 records for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 09:21:05 HD Request # 30 - Intraday download COMPLETE for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 09:21:05 Real-time intraday chart data file updates started for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 09:21:05 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 09:22:03 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 09:22:03 The SSL socket was shut down successfully. | 2013-08-06 09:22:03 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 09:22:03 CTS Historical FIX Session: Disconnected. | 2013-08-06 09:22:03 Ignored socket Close call based on current socket state. | 2013-08-06 09:22:03 HD Request # 31 - Downloading Intraday chart data for 6J.CME_20130900_6JU3.CME_Fo to the file 6J.CME_20130900_6JU3.CME_Fo.scid. Service: cts | 2013-08-06 09:22:04 HD Request # 31 - Starting date and time: 2013-08-06 08:59:58.0 | 2013-08-06 09:22:04 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 09:22:04 The network socket is connected. | 2013-08-06 09:22:05 The socket starting SSL connection. | 2013-08-06 09:22:05 SSL socket is now connected. | 2013-08-06 09:22:05 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 09:22:05 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 09:22:06 HD Request # 31 - Requesting historical Tick data for 6J.CME_20130900_6JU3.CME_Fo from 2013-08-05 to 2013-08-06 | 2013-08-06 09:22:06 HD Request # 31 - Requesting historical Tick data for 6J.CME_20130900_6JU3.CME_Fo from 2013-08-06 to 2013-08-07 | 2013-08-06 09:22:07 HD Request # 31 - Timestamp of first Intraday data file record written: 2013-08-06 08:59:58 | 2013-08-06 09:22:08 HD Request # 31 - Received 109665 records and wrote 4832 records for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 09:22:08 HD Request # 31 - Intraday download COMPLETE for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 09:22:08 Real-time intraday chart data file updates started for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 09:22:08 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 09:23:07 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 09:23:07 The SSL socket was shut down successfully. | 2013-08-06 09:23:07 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 09:23:07 CTS Historical FIX Session: Disconnected. | 2013-08-06 09:23:07 Ignored socket Close call based on current socket state. | 2013-08-06 09:23:07 HD Request # 32 - Downloading Intraday chart data for CL.CME_20130900_CLU3.CME_NY to the file CL.CME_20130900_CLU3.CME_NY.scid. Service: cts | 2013-08-06 09:31:00 HD Request # 32 - Starting date and time: 2013-08-06 07:54:59.0 | 2013-08-06 09:31:00 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 09:31:00 The network socket is connected. | 2013-08-06 09:31:00 The socket starting SSL connection. | 2013-08-06 09:31:00 SSL socket is now connected. | 2013-08-06 09:31:00 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 09:31:00 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 09:31:01 HD Request # 32 - Requesting historical Tick data for CL.CME_20130900_CLU3.CME_NY from 2013-08-05 to 2013-08-06 | 2013-08-06 09:31:01 HD Request # 32 - Requesting historical Tick data for CL.CME_20130900_CLU3.CME_NY from 2013-08-06 to 2013-08-07 | 2013-08-06 09:31:04 HD Request # 32 - Timestamp of first Intraday data file record written: 2013-08-06 07:54:59 | 2013-08-06 09:31:06 HD Request # 32 - Received 189793 records and wrote 43342 records for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 09:31:06 HD Request # 32 - Intraday download COMPLETE for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 09:31:06 Real-time intraday chart data file updates started for CL.CME_20130900_CLU3.CME_NY | 2013-08-06 09:31:06 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 09:32:04 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 09:32:04 The SSL socket was shut down successfully. | 2013-08-06 09:32:04 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 09:32:04 CTS Historical FIX Session: Disconnected. | 2013-08-06 09:32:04 Ignored socket Close call based on current socket state. | 2013-08-06 09:32:04 HD Request # 33 - Downloading Intraday chart data for GC.CME_20131200_GCZ3.CME_CO to the file GC.CME_20131200_GCZ3.CME_CO.scid. Service: cts | 2013-08-06 09:32:35 HD Request # 33 - Starting date and time: 2013-08-06 08:34:58.0 | 2013-08-06 09:32:35 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 09:32:35 Error connecting socket: Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-08-06 09:32:56 CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-06 09:32:56 CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-06 09:32:56 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 09:33:01 Error connecting socket: Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-08-06 09:33:22 CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-06 09:33:22 CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-06 09:33:22 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 09:33:27 The network socket is connected. | 2013-08-06 09:33:27 The socket starting SSL connection. | 2013-08-06 09:33:27 SSL socket is now connected. | 2013-08-06 09:33:27 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 09:33:27 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 09:33:28 HD Request # 33 - Requesting historical Tick data for GC.CME_20131200_GCZ3.CME_CO from 2013-08-05 to 2013-08-06 | 2013-08-06 09:33:28 HD Request # 33 - Requesting historical Tick data for GC.CME_20131200_GCZ3.CME_CO from 2013-08-06 to 2013-08-07 | 2013-08-06 09:33:30 HD Request # 33 - Timestamp of first Intraday data file record written: 2013-08-06 08:34:58 | 2013-08-06 09:33:32 HD Request # 33 - Received 147538 records and wrote 18228 records for GC.CME_20131200_GCZ3.CME_CO | 2013-08-06 09:33:32 HD Request # 33 - Intraday download COMPLETE for GC.CME_20131200_GCZ3.CME_CO | 2013-08-06 09:33:32 Real-time intraday chart data file updates started for GC.CME_20131200_GCZ3.CME_CO | 2013-08-06 09:33:32 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 09:34:30 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 09:34:30 The SSL socket was shut down successfully. | 2013-08-06 09:34:30 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 09:34:30 CTS Historical FIX Session: Disconnected. | 2013-08-06 09:34:30 Ignored socket Close call based on current socket state. | 2013-08-06 09:34:30 HD Request # 34 - Downloading Intraday chart data for 6E.CME_20130900_6EU3.CME_Fo to the file 6E.CME_20130900_6EU3.CME_Fo.scid. Service: cts | 2013-08-06 11:03:48 HD Request # 34 - Starting date and time: 2013-08-06 10:39:59.0 | 2013-08-06 11:03:48 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 11:03:48 The network socket is connected. | 2013-08-06 11:03:48 The socket starting SSL connection. | 2013-08-06 11:03:48 SSL socket is now connected. | 2013-08-06 11:03:48 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 11:03:48 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 11:03:49 HD Request # 34 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-05 to 2013-08-06 | 2013-08-06 11:03:49 HD Request # 34 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-06 to 2013-08-07 | 2013-08-06 11:03:51 HD Request # 34 - Timestamp of first Intraday data file record written: 2013-08-06 10:39:59 | 2013-08-06 11:03:53 HD Request # 34 - Received 201795 records and wrote 4492 records for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 11:03:53 HD Request # 34 - Intraday download COMPLETE for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 11:03:53 Real-time intraday chart data file updates started for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 11:03:53 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 11:04:51 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 11:04:51 The SSL socket was shut down successfully. | 2013-08-06 11:04:51 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 11:04:51 CTS Historical FIX Session: Disconnected. | 2013-08-06 11:04:51 Ignored socket Close call based on current socket state. | 2013-08-06 11:04:51 HD Request # 35 - Downloading Intraday chart data for 6E.CME_20130900_6EU3.CME_Fo to the file 6E.CME_20130900_6EU3.CME_Fo.scid. Service: cts | 2013-08-06 11:38:47 HD Request # 35 - Starting date and time: 2013-08-06 11:14:51.0 | 2013-08-06 11:38:47 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 11:38:47 Error connecting socket: Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-08-06 11:39:08 CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2013-08-06 11:39:08 CTS Historical FIX Session: Problem connecting to Historical data server. Will retry. | 2013-08-06 11:39:08 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 11:39:13 The network socket is connected. | 2013-08-06 11:39:13 The socket starting SSL connection. | 2013-08-06 11:39:13 SSL socket is now connected. | 2013-08-06 11:39:13 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 11:39:13 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 11:39:14 HD Request # 35 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-05 to 2013-08-06 | 2013-08-06 11:39:14 HD Request # 35 - Requesting historical Tick data for 6E.CME_20130900_6EU3.CME_Fo from 2013-08-06 to 2013-08-07 | 2013-08-06 11:39:16 HD Request # 35 - Timestamp of first Intraday data file record written: 2013-08-06 11:14:51 | 2013-08-06 11:39:18 HD Request # 35 - Received 204973 records and wrote 1924 records for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 11:39:19 HD Request # 35 - Intraday download COMPLETE for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 11:39:19 Real-time intraday chart data file updates started for 6E.CME_20130900_6EU3.CME_Fo | 2013-08-06 11:39:19 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 11:40:16 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 11:40:16 The SSL socket was shut down successfully. | 2013-08-06 11:40:16 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 11:40:16 CTS Historical FIX Session: Disconnected. | 2013-08-06 11:40:16 Ignored socket Close call based on current socket state. | 2013-08-06 11:40:16 HD Request # 36 - Downloading Intraday chart data for 6J.CME_20130900_6JU3.CME_Fo to the file 6J.CME_20130900_6JU3.CME_Fo.scid. Service: cts | 2013-08-06 11:46:29 HD Request # 36 - Starting date and time: 2013-08-06 11:09:53.0 | 2013-08-06 11:46:29 CTS Historical FIX Session - Connecting to Historical data server: fix-chart.t4login.com | 2013-08-06 11:46:29 The network socket is connected. | 2013-08-06 11:46:30 The socket starting SSL connection. | 2013-08-06 11:46:30 SSL socket is now connected. | 2013-08-06 11:46:30 CTS Historical FIX Session: Sending the Logon message. | 2013-08-06 11:46:30 CTS Historical FIX Session: Connected to Historical data server. | 2013-08-06 11:46:32 HD Request # 36 - Requesting historical Tick data for 6J.CME_20130900_6JU3.CME_Fo from 2013-08-05 to 2013-08-06 | 2013-08-06 11:46:32 HD Request # 36 - Requesting historical Tick data for 6J.CME_20130900_6JU3.CME_Fo from 2013-08-06 to 2013-08-07 | 2013-08-06 11:46:34 HD Request # 36 - Timestamp of first Intraday data file record written: 2013-08-06 11:09:53 | 2013-08-06 11:46:36 HD Request # 36 - Received 128731 records and wrote 972 records for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 11:46:36 HD Request # 36 - Intraday download COMPLETE for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 11:46:36 Real-time intraday chart data file updates started for 6J.CME_20130900_6JU3.CME_Fo | 2013-08-06 11:46:36 CTS Historical FIX Session: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2013-08-06 11:47:34 CTS Historical FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-08-06 11:47:34 The SSL socket was shut down successfully. | 2013-08-06 11:47:34 CTS Historical FIX Session: Logged out and disconnected. | 2013-08-06 11:47:34 CTS Historical FIX Session: Disconnected. | 2013-08-06 11:47:34 Ignored socket Close call based on current socket state. | 2013-08-06 11:47:34 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:30:00. Current Date Time: 2013-08-06 10:30:00. Filename: C:\SierraChart\Data\HG.CME_20130900_HGU3.CME_CO.scid | 2013-08-06 13:19:13 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:34:00. Current Date Time: 2013-08-06 10:34:00. Filename: C:\SierraChart\Data\HG.CME_20130900_HGU3.CME_CO.scid | 2013-08-06 13:19:13 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:30:00. Current Date Time: 2013-08-06 10:30:00. Filename: C:\SierraChart\Data\HG.CME_20130900_HGU3.CME_CO.scid | 2013-08-06 13:19:13 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:34:00. Current Date Time: 2013-08-06 10:34:00. Filename: C:\SierraChart\Data\HG.CME_20130900_HGU3.CME_CO.scid | 2013-08-06 13:19:13 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:30:00. Current Date Time: 2013-08-06 10:30:00. Filename: C:\SierraChart\Data\HG.CME_20130900_HGU3.CME_CO.scid | 2013-08-06 13:19:13 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:30:00. Current Date Time: 2013-08-06 10:30:00. Filename: C:\SierraChart\Data\HG.CME_20130900_HGU3.CME_CO.scid | 2013-08-06 13:19:13 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:30:00. Current Date Time: 2013-08-06 10:30:00. Filename: C:\SierraChart\Data\HG.CME_20130900_HGU3.CME_CO.scid | 2013-08-06 13:19:13 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:00:00. Current Date Time: 2013-08-06 10:00:00. Filename: C:\SierraChart\Data\HG.CME_20130900_HGU3.CME_CO.scid | 2013-08-06 13:19:13 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:00:00. Current Date Time: 2013-08-06 10:00:00. Filename: C:\SierraChart\Data\HG.CME_20130900_HGU3.CME_CO.scid | 2013-08-06 13:19:14 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:29:00. Current Date Time: 2013-08-06 10:25:00. Filename: C:\SierraChart\Data\6J.CME_20130900_6JU3.CME_Fo.scid | 2013-08-06 13:24:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:25:00. Current Date Time: 2013-08-06 10:25:00. Filename: C:\SierraChart\Data\6J.CME_20130900_6JU3.CME_Fo.scid | 2013-08-06 13:24:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:25:00. Current Date Time: 2013-08-06 10:25:00. Filename: C:\SierraChart\Data\6J.CME_20130900_6JU3.CME_Fo.scid | 2013-08-06 13:24:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:29:00. Current Date Time: 2013-08-06 10:25:00. Filename: C:\SierraChart\Data\6J.CME_20130900_6JU3.CME_Fo.scid | 2013-08-06 13:24:37 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:15:00. Current Date Time: 2013-08-06 10:15:00. Filename: C:\SierraChart\Data\6J.CME_20130900_6JU3.CME_Fo.scid | 2013-08-06 13:24:38 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:15:00. Current Date Time: 2013-08-06 10:15:00. Filename: C:\SierraChart\Data\6J.CME_20130900_6JU3.CME_Fo.scid | 2013-08-06 13:24:38 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:20:00. Current Date Time: 2013-08-06 10:20:00. Filename: C:\SierraChart\Data\6J.CME_20130900_6JU3.CME_Fo.scid | 2013-08-06 13:24:38 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:00:00. Current Date Time: 2013-08-06 10:00:00. Filename: C:\SierraChart\Data\6J.CME_20130900_6JU3.CME_Fo.scid | 2013-08-06 13:24:38 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-06 11:00:00. Current Date Time: 2013-08-06 10:00:00. Filename: C:\SierraChart\Data\6J.CME_20130900_6JU3.CME_Fo.scid | 2013-08-06 13:24:38 |
[2013-08-06 19:23:18] |
It is clear there is some problem with the timestamps data from CTS using FIX. When you notice the problem, you then need to go into the Intraday editor and look at the timestamps for the data file. Of course, after you re-download the historical data, the timestamps will look fine. For help with out of order timestamp errors you are getting in the Message Log, refer to this page here: http://www.sierrachart.com/index.php?l=doc/helpdetails63.html The connection errors you are referring to, are common when connecting to the CTS chart data server. The Message Log is just simply logging what is happening. That is all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-06 19:26:08
[2013-08-06 20:10:43] |
MMX - Posts: 119 |
OK, I can do that tomorrow, but then what? Do I send the timestamp info to you? Is this being done to confirm that it is a timestamp problem? Or is this being done just to let me know "Yep, you need to delete and download". Are you aware of anyone else having this problem?
[2013-08-06 20:22:58] |
We want to know more information about the timestamps so we can let CTS know precisely what the problem is. We do have other reports of timestamp issues.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-06 20:23:26
[2013-08-07 19:13:44] |
MMX - Posts: 119 |
There were 7 spikes today that I'm aware of, 5 of them in the Euro, 2 of them in the Yen. I got numbers on 4 of the Euro spikes and numbers for 1 Yen spike. All the spikes I've seen in the past 3 days have spiked downward, no up spikes and the 5 Euro spikes today all stopped at the 13307 low. Euro 10:34:33.4 13326 10:34:35.0 13326 normal 10:34:36.0 13307 spike 10:34:36.1 13307 spike 10:34:44.0 13326 normal 11:20:11.8 13322 11:20:11.9 13322 normal 11:20:11.10 13307 spike 11:20:31.0 13323 normal 11:20:31.1 13323 12:44:30.2 13340 12:44:34.0 13340 normal 12:44:37.0 13307 spike 12:44:42.0 13339 normal 12:44:42.1 13339 13:21:41.5 13340 13:21:41.6 13340 normal 13:21:41.7 13307 spike 13:21:42.0 13340 normal 13:21:42.1 13340 Yen 13:21:49.2 10371 13:21:49.3 10371 normal 13:21:50.0 10243 spike 13:21:50.1 10372 normal 13:21:51.0 10371 |
[2013-08-07 21:04:52] |
OK this is different than we thought. In any case, we need to report this to CTS. They will ask us for your CTS T4 Username and Firm. Please send those through an Account Support Ticket here: https://www.sierrachart.com/usercp.php?page=SupportTickets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-09 07:54:07] |
This problem is now resolved. Please update to version 1007 when you can.
[2013-08-09 08:13:16] |
ganz - Posts: 1048 |
SC Team I'd like to say Thank You for CTS T4 FIX has been added (and for CQG FIX will be added soon). This is the most professional choise, imho. With best regards. |
